Speedometer shakes!
Speedometer shakes!
Hello guys, my Sierra 2.0 from 1985 has a nasty problema
From when i start moving my speedometer will shake everytime and imagine im going 20mph, it shakes from 0 to 40 and keeps like that all day.
What i can i do to solve the problem?
Thank you
Thank you
I recently had the same fault. This is what I did:
Cheers,
- Opend the engine bay.
- Identify and loosen the speedo cable.
- Get underneath the car where the cable goes into the gearbox/speedo drive and remove the cable. There is a circlip holding it.
- I took the dash apart.
- Removed and unplugged the wiring from the instrument panel. Becarefull not to yank it.
- You have to unclip the speedo cable holder off the casing of the back of the instrument pannel where it is connected.
- The inner cable(spring like cord) will slide out the outer cable casing/sheath.
- Once out, inspect for kinks.Inspect the sheath for kinks or damage.If none, lubricate the cord and slide back into the casing/sheath.
- Plug back wiring on the the instrument panel, also dont forget to clip the speedo cable back on. usually its the white connecter.
- Put the dash back together.
- Go to the engine bay and manipulate the cable so it gets routed nicely and neatly to the gearbox.
- With a longnose plier you have to insert the cord into the speedo drive. then clip the sheath mounting back into position with the circlip.
- Take it for a test drive.
Cheers,
Sheepdisease
30-08-2015 09:11 PM
