st escos inlet plenum and tb onto my 2wd
i just got the plenum and tb now with the original st escos sensors. What is needed to run this on my 2wd?
Luke
Luke
cossie fan (unluckerly)
is he? any way when mine was running a st escort inlet set up it just used all the rwd sensors as far as i know but i never fitted it as it was done at m.a.d but i do remember there was a plate welded on to the bottom where a pipe once was as for the throttle cable it was done via the st escort cable backet
CheeRS.Lee.
Gary Krishna
I made an adaptor piece to allow the PF09 to work on the ST throttle body, made it from a spindle out of an old 2wd throttle body.
The actual mounting base for the TPS can be removed from the Weber throttle body and fitted straight onto the ST throttle body, fits perfectly.
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
