map sensor location and position in a kitcar Question
Hi guys im building a cosworth powered westfield and a comment arose a few weeks back just need to clarify to be fair guys if you a can help me please share your view...
Q1 ... my 3 Bar map sensor is mounted verticle ie vac hose facing toward you, and is with in 4" iches of a group A coil...is this ok or is it no good placement wise etc etc...
Q2 ...my ignition amplifier is mounted also within 3" of the coil again will this cause any issues etc...
Rob
Rob
Map sensor should be mounted with hose on underside, they had a recall on 3 doors to fit a bracket to mount it this way as some where failing. The wiring to it should be shielded to prevent interference but I would still keep it as far away from ht leads and coil as I could just to be sure no issues. But 3 inches is probably enough.
The ignition amp on std 3 door is right next to the coil so can't see that being an issue
wheelwizardrefurbs
24-09-2015 08:35 PM
