No fan
Exactly what he ^^ says, this is the first thing to do.
If it's a Cosworth then it's likely the fuse has melted in the fusebox (Caused by Ford fitting a switch that isn't suitable), but irrelevant of this the fans should be rewired anyway, if you do a search on here you will see all the threads about it.
Martin
Martin
My 91 4x4 saph done same after stint in garage (10 year)
Changed switch .. But also changed to a new loom for fans as said above original are not too good and have been known to catch fire .. Never had a prob since
Classic problem, as I say above, it is common for it to melt as well!
Rewire the fans BEFORE it damages the fuse box etc, the standard setup/wiring is shocking, the fuel pump also suffers from old wiring and cause cause a meltdown, these are two chronic weak points and both need rewiring!
Martin
Martin
