Finding an air leak - how to test?
Hi all,
OK - convinced I have an air leak on my sapphire as bit by bit its starting to do funny things.
Pretty confident its the plenum gasket - cheap and easy to do, but does anyone have a trick up their sleeve for pressurising the system and finding the leaks this way too?
Huw
Huw
I have done this a couple of times on different Cosworths. I take of the hoose between turbo and ic on the turbo end. Block it whit a spray can or simillar. Then use 2,5-3bar pressure air in one of the vakum hoose on inlet. You will hear it if it`s a big leak or you can use soap water to spray on, and look after bubbles, this work for me
We have rubber plugs whit valves, who we use on trucks. You don`t have to use a one way valve, because the pressure will not stay any way, some valves are always open. Or you will have to take inlet cam out
Thinking Cosworth..
I use the cap of a spraycan and fit a valve in it, the one where you can presurise you car tyre with. Then remove the hose from airbox to turbo and fit this cap in a piece of 60mm hose with some good clamps and put this on the turbo. This way you set the pressure on the whole system including the turbo. Then put 2.5 Bar to it and listen for any sissling noices. You will be surpriced how much leaks you will find!
Try this ... got one of those af found several small leaks by following their 101 test and soap water
http://www.turboboostleaktesters.com/servlet/StoreFront
lee2cossies
26-08-2015 10:04 PM
borboyous
22-08-2015 11:17 AM
