Sierra Rev Counter
Sierra Rev Counter
Well here iam again, probably asking a silly question but here it goes
My Sierra Hatch doesn't have a REv counter and im about to buy some other dials with a rev counter. Where do i connect so i can get negative (i think it works with negative), so i can make the rev counter work?
Thank you guys!
Thank you guys!
Yes instrument cluster is the same, as is the dash, more below.
You MAY however find you have a different type of dash, as there were so many different types fitted, as yours does not have a tacho and an analogue clock in it's place, as said, It's going to be a base model, but what year is it ?
I suspect your speedo is a 130 MPH unit?
The instrument cluster's and the dash are the same BUT differ massively dependent on year, for example 90 spec onwards cars had adjustable steering, along with the revised "hooded" dashboard as it's known, and these are not a straight swap
It's only all I have seen of the later clusters had rev counters, even the LX has a rev counter but it should still fit never the less I should think, imo the later type looks better anyway!
Also tachos are scaled to the engine (Except aftermarket which are designed for a variety of engines), I should think another one from another model would be ok though as there was very little difference in them.
But yes in the case if a electric rev counter, it simply has a live, and in the conventional manner like the set up on these, the ground connects to the ground side of the coil (Green wire) this is the signal line effectively.
Martin
Martin
Martin
Martin
The adjustable steering messes anything with swtiching the dashs?
By the way you know if the doors from the sierra mk1 5 door model will fit in the sierra mk2 4 door model? The one with the big boot like the orion
If it's a MK1 then it will certainly have a 130 MPH speedo.
We did have a GL in the UK, it wasn't actually a bad specced model.
The Sierra saloon is known as the "Sapphire" and yes the doors are interchangeable with a MK2 hatch, I am not sure however the same would be true interchanging between MK1 and MK2 as you would be doing in your case, probably not I suspect.
Yes the 90 spec onwards cars had revised dashes and had two glove boxes, I am not even sure if you can fit these dashes to the earlier cars but you certainly can't go the other way as the early dash won't fit the later car due to the steering adjustment etc.
Martin
Martin
chowfornow
14
05-01-2019 09:01 PM
wheelwizardrefurbs
22-09-2015 05:45 PM
