Gripper Differentials anyone ??????
I run two! one in a Clio, one in a Westfield. The Clio one WAS noisy but isn't now it has the correct oil in it. Been reliable and work well. Westfield one is a ford diff. Same as what you would use in a Sierra. The weak point will still be the standard ford CWP and I have broken one of these already.
cossie fan (unluckerly)
yes but there is 4! heres a good pic on this link under axles! this company is a uk agent for them
http://www.robinson-race-cars.co.uk/
yes but 4 theres a good pic on this link under axles! this company is a uk agent for them
my c.w.p was done at hewland engineering and i have an m.a.d 500/500 set up and it hasent busted yet (did with a standard c.w.p) but then i dont drive like a twat so sould be fine but if it go,s again ill fit a supra one
Its not a problem with the crown wheel as such ,the main problem is that the casing splay as the pinion tries to push the crownwheel out of mesh when transmitted high torque loads which was a problem we had on the original Cosworth challange cars and was all but cured by fitting dowels to the corners back cover
351RS
11
07-04-2007 09:50 AM
