Fitting an oil gauge
Old 08-06-2012, 10:51 PM
langer
langer's Avatar
Default Fitting an oil gauge
Rite guys this might sound daft but ive got some ford racing gauges one of which is an oil pressure gauge. I bought a alloy adapter piece offline and already have a pipe. I had a little look today and my question is rite, is the adaptor supposed to go In between the unit which the oil switch is in and the turbo feed pipe facing outwards? Or screw in where the oil switch goes as in going upwards? Just my oil kidney box would seem to be in the way? If going the upwards way. Cheers in advance
Old 10-06-2012, 08:54 AM
langer
langer's Avatar
Anyone!
Old 10-06-2012, 09:54 AM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
I would get a sandwich plate that goes in between the oil filter arm and oil filter (4x4) or just between the block and filter (2wd). You can also then fit other oil gauge senders. Like this.
Plenty on eBay. ;D
Old 10-06-2012, 10:17 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
drill and tap the one thats alraedy on the car i think its 1/8ntp then you can run all 3 much easier than buying a sandwich plate
Old 10-06-2012, 10:08 PM
langer
langer's Avatar
Mines a 2wd so doesn't have a sandwich plate at all it has an oil cooler plate with 2 water pipes on it
RUBY123
22-10-2023 12:04 PM
mrmann
20-08-2015 11:24 PM
JoeyBoyden
18-08-2015 10:52 PM
track.focus'd
12-08-2015 05:53 PM
no1trancefan
Ford Focus ST
07-08-2015 09:21 PM
Quick Reply: Fitting an oil gauge
