rear door cant open !
Hi I've had my back door handles smoothed but I don't know why but I put child lock on lol and now I can't open the door lol can you help me ?
If the speaker is in door best to rip panel off take speaker out and grab locking mechisim its a bitch to feel round but is do able.
Best of luck though
Best of luck though
There are no speakers in the rear doors, along the same line, however, damaging the rear door card to remove it is the only way I can see so you can gain access to the lock mechanism (Removing the rear seats will help you) as you can't remove the fixings without the door being open.
This is the reason I can never understand the logic in removing door handles and locks
Martin
Martin
Martin
Martin
You'll be able to get down the window trim in the same way you would with the fronts if say you'd locked your keys in it. You'll need something like a metal ruler with a notch in it unless you know someone with a lock out kit. I have one but a little far away to do it for you. Try and catch an aa man they have the kits I think
If you take the padded bit of the door card off and cut a hole you can get your hand in that way, then glue the padding bit back, I got in mine that way.
Martin
borboyous
22-08-2015 11:17 AM
mrice0107
21-08-2015 07:55 PM
