What Engine mounts?
What Engine mounts?
Morning all,
Need some advise please.... my 4x4 has a 2wd conversion. What engine mounts should this have as I have some exhaust clearance issues.
Huw
Huw
If it's been converted to 2wd it should have a 2wd crossmember, mount's and i'm not 100% sure but the downpipe may need to be 2wd (i know systems are different)
your mounts should look like this
uprated 2wd mount
http://www.ebay.co.uk/itm/RS-Coswort...item255364013a
std 2wd mount
http://www.ebay.co.uk/itm/Cosworth-2...item2a1e61e027
if they are right then you may have to look at the downpipe
or crossmembers
2wd
http://www.ebay.co.uk/itm/SIERRA-2WD...item2570347fa4
4x4
http://www.ebay.co.uk/itm/COSWORTH-S...item257076620a
uprated 2wd mount
std 2wd mount
or crossmembers
2wd
4x4
uprated 2wd mount
std 2wd mount
or crossmembers
2wd
4x4
uprated 2wd mount
std 2wd mount
or crossmembers
2wd
4x4
The exhaust I have is a 4x4 and its fouling the box. The downpipe is also really close to the bulkhead. To be fair, the 2wd downpipe I had was the same in that respect.
It looks like the engine could do with moving up an inch - thats all it needs.
I also get quite a judder when pulling off
Was hoping this was an engine mount issue? What you guys rekon??
Huw
Mate thats really helpfull. Looking at it just now, id say I have a 2wd cross member and setup. Mounts are standard.
Huw
Huw
Thats my theory look at your exhaust as you really need a 2wd complete system that runs down the drivers side of the box
I may be wrong here but i'm guessing your issue stems from the system passing under the box to run down the opposite side - this is pulling the downpipe downwards and completely in the wrong position - their was a reason they redesigned the 2wd ex system when they did 4x4
track.focus'd
12-08-2015 05:53 PM
lockie
31-07-2015 10:03 PM
