3dr offsets
3dr offsets
Im thinking of putting new wheels on the my 3dr, but yet again I have forgotten the correct offsets lol!
Can anyone tell me what these are?
I have found a set of 15" the fronts are 7J ET20 and the back 8J ET15 are these any good?
CheeRS in advance
Callum.
CheeRS in advance
Callum.
www.ebay.co.uk/itm/270967259357?
cheap and cheerful wheels
3 door and 2wd saff are et37 and 4x4 saff is et40 ,ecos is et25
Mine are 8j et30 on the rear
et30 7j on the front and it drives and sits well
Et 15 on a 3 door will kill tyres,arches and drive like a bag of shite .
Im now on my 7th set of wheels so been there done it
Those rear wheels are too wide - they will run 14mm wider than my rears which are 8.5" ET22 and my arches have been rolled to the limit and kit trimmed right back so to get thwm on your going to need to either ride with the rear on standard height or cut the complete arch off reweld the inner and outer rear quarters back together and bond your fully trimmed kit back on
If they were a rare desirable rim then you could be persuaded to do the work but for a set of wheels worth a few hundred quid and the possiblity of running in a proper size you would be mad to even bother.
I would go for a set of these in either Gold, Silver or black in 17"
Sizes i would go for an 7.5" front ET25 and 8.5" rear ET25 these have been on a 3dr on here before and sit very well on the car i'm sure i have a picture of it somewhere i will try and find it
These company's can help
http://www.ebay.co.uk/itm/Lenso-BSX-...item27c59b037d
http://caraudiosecurity.com/shop/pro..._id/15207.html
Hi. i dont know if this ill help. but ive got a 3 door fiesta 51 plate and my standard wheels are et40 and just fitted et 20 on front 7j and et 15 on thr rear 8j. the lip of the wheels poke out so i have got little strech on the alloys. hope this helps.
Playing around with the offset even dropping back to a ET30 would give you 5mm extra space
Also the height of the car plays a part in it.
Lee what you thinking mate?
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
