how can i tell what map sensor i got
what can tell me if i have a standard map sensor or 3bar? Its only stage 1 but would still like to check as boost is now about 15psi
It should be mounted to the inner wing. To the left of the header tank, upside down. 3 x 10mm bolts hold it in. I'd say yes to see part number. But if you know who's chip it is. Just give them a shout and ask if they fit a 3 bar. I very much doubt it.
95% sure it'll be standard
hi martin. I put a post up about it a while ago which u commented on. There was no pre load on actuator and i was down on power. Just need a new chip to take into abount voltage chance between standard map and 3 bar one iirc. Injector are still within safe limits
are 4x4 and 2wd map sensors different? i've read the wiring is different as the 2 end pins are the other way round? if thats the case can i swap them round and use a 2wd map sensor on a 4wd?
cheers
cheers
