Diff mount all fitted
Old 27-05-2012, 09:55 PM
Harris.
Harris.'s Avatar
Default Diff mount all fitted
Well after some messing about with the bolts i fitted the new diff mount i got from msd, took the car out after just to make sure it was all ok
From getting in the car it felt higher at the back and alot more SOLID, got a few miles down the road and i must say its makes such i differnce to the feel of the whole car . A must have /fit for £120
Next up is to get some new springs ,as mine look like they have sat on the bottom of a river for 26 years and why i was under the car i noticed my rear anti roll bar bushes are falling apart so i will get both items during the week ready for next weekend.
But all in all im happy
Old 28-05-2012, 04:39 PM
BRAMMER
BRAMMER's Avatar
Mine has countersunk bolts so shouldn't foul the roll bar
I can't wait to feel what my car is like when back on the road
Old 28-05-2012, 05:27 PM
Paul_RS
Paul_RS's Avatar
Have to agree, makes a massive difference and is a must have modification!
Old 28-05-2012, 05:52 PM
RONNIE AMIS
RONNIE AMIS's Avatar
It's something I recommend to anybody with a cosworth. Makes an incredible difference
Old 28-05-2012, 08:45 PM
Puss2
Formerly know as Puss
Puss2's Avatar
As above Ronnie told me to change mine i didnt think it would feel any different but was like a different car after
Old 28-05-2012, 09:28 PM
tosh
tosh's Avatar
I also fitted Collins engine mounts and vib-technics gearbox mount,
And now it feels like a new machine
Old 28-05-2012, 10:09 PM
Rsmat
300+
Rsmat's Avatar
I fitted mine and put MSD's engine mounts...lowered the car 20mm on Ahmed bajoo springs and fitted camber shims and poly bushed the 3dr and it feels fucking brilliant on the road... The diff mount makes a proper difference..!!
Old 29-05-2012, 12:14 PM
Harris.
Harris.'s Avatar
I think i have to get back under the car and adjust it as the washer the sits between the mount and the diff has a 3mm gap and it dont look right , maybe i didnt cut the bolts short enough , so ive gone and got 6cm 7cm and 8cm to see which ones fit best .
Not a dig but maybe it may be worth looking at the bolts you supply for ones that are the right length it would say a bit of messing about .
But again a nice item for £120
Old 12-06-2012, 09:01 PM
Harris.
Harris.'s Avatar
So ive had this fitted a few weeks now, but feeling a vibration through the gear stick and back end ?is this normal as the mount is more solid etc ,im also get a slight clonk - knocking from the passenger rear side? thinking anti roll bar bushes ?
Old 12-06-2012, 09:27 PM
botters
competant bodger
botters's Avatar
didnt realise they made such a difference! my msd one has been sat on top of my toolbox for about 6 months lol, must get it fitted at the weekend
Old 12-06-2012, 09:30 PM
tosh
tosh's Avatar
As I said above I fitted Diff, Gearbox & engine mounts & have not really noticed any increase in noise or vibration, but needed to replace the diff mount top bolt to a countersunk bolt to clear the ARB,
You might be getting the noise/vibration from the bolt hitting the ARB whilst driving.
Old 12-06-2012, 09:58 PM
cossie.087
cossie.087's Avatar
fitted mine afew weeks ago,must say its massive.i to have a vibration iam thinking it could be my drive shaft a knock on effect of every thing being so solid with the new mount.
Old 13-06-2012, 07:35 AM
Harris.
Harris.'s Avatar
I have powerflex rear anti roll bar bushes on order and im hopeing this will solve the noise etc
Old 13-06-2012, 12:25 PM
opposite lock
opposite lock's Avatar
After having mine fitted it made the car feel more sat up and once the power is applied it all feels like its going into the road. My saph felt soooo vague before this upgrade. Must get them countersunk bolts too.
Old 13-06-2012, 03:50 PM
KSA-Cossie
KSA-Cossie's Avatar
Solid beam mounts help too.
Old 16-06-2012, 06:25 PM
steventoon
steventoon's Avatar
Do you feel a lot more vibration through the car? I'm thinking of taking my MSD read diff mount and rear beam poly bushes off as I think these are the cause of the vibration.
Old 16-06-2012, 08:31 PM
1374lee
1374lee's Avatar
I've just bought one of these mounts,waiting on delivery now.I had an MCR diff mount which I purchased brand new for my old 3dr and never had a problem with vibration,I hope the msd one is the same fingers crossed.
Thanks.Lee.
Old 16-06-2012, 08:34 PM
Harris.
Harris.'s Avatar
Yes you do,i was out in the cossie today again and theres alot more vibration, and a knocking . but once new bushes are fitted etc i hope it cure's it .
Old 17-06-2012, 08:09 AM
steventoon
steventoon's Avatar
I think the roll bar bushes will only worsen the vibration mate. I'm de polybushing my car for that reason. The only ones ill keep are the tca on the front.
Old 17-06-2012, 09:55 AM
KSA-Cossie
KSA-Cossie's Avatar
I took my solid beam mounts off due to noise,they do work well though.
Old 17-06-2012, 10:32 AM
JamesH
JamesH's Avatar
Mine put a fair bit more vibration through the car, but wasn't an MSD one
Old 17-06-2012, 10:37 AM
DAN400
DAN400's Avatar
i must be the only person on passionford that fitted a new diff mount and never noticed one bit of difference
Old 17-06-2012, 12:14 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Me either
Maybe we are both thick lol
Steve
Old 17-06-2012, 05:04 PM
Harris.
Harris.'s Avatar
Guess you 2 have better bushes fitted or your standard ones are still ok ?? I think as the diff has lifted about 2 inches now i need to also change gearbox mounts, as with most mods ,you change one thing and end up having to change a few other items too........
Old 17-06-2012, 08:16 PM
tosh
tosh's Avatar
I was advised that if you go down the uprated Gearbox mount route you should also do the engine mounts at the same time so they have the similar flexibility/strength
Old 17-06-2012, 08:37 PM
KSA-Cossie
KSA-Cossie's Avatar
Updated engine mounts yes, but leave the standard gearbox mount in.
09-10-2015 07:38 PM
Chas
21-09-2015 08:57 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
xr4x4rs
06-08-2015 09:03 PM
Quick Reply: Diff mount all fitted
