Who does bombproof YB-block?
So you have used those your self. Any other high power engines with these ones?
And how much these and machining cost?
Well why not.
Actually, it is not very important, because I have to anyway buy a new internal parts. Of course more volume would be good, because I'm using GTX4294.
Stroke I want to keep close original, because I like to have rod ratio what makes sense to me. And I want it to rev easily and high (+9000rpm).
Hope this makes sense, I'm not so good in english.
Are you going to a longer rod with the std stroke?
That turbo is a monster. I asume from that your chasing over 600hp!
If I had an unlimited budget I would be going for a tall deck alloy block with a 2.3lt stroker bottom end.
What plans do you have?
Alloy block is one possible idea, but don't know that how does it work. Not so many people using that one.
I think the reason not alot of people are using them is because there not exactly cheap!
Might be best to track down a suplier, like Burton Power, and ask them about the block. They should have all the details you need.
Get intouch with mk motorsport of here..
I have a 200 block fully machined out with a 25mm block spacer that obvioulsy makes it a bigger capacity but strengthens the block,then i have 6mm thick steel wet liners pressed in and then to top that off i have one of his block girdles to make it even stronger through the main caps..imo its the best possible and strongest blocks available ..
cheers danny
cheers danny
cheers danny
cheers danny
Yes I have been, but I have not remembered to ask about this possibility.
And yes, I have intention to buy his girdle and drysump kit.
Ask him about dannys (thats me) engine etc??
He is helping to build my whole car,alot of his stuff has gone into it and im going to advertise his business with my car and help sell many more products for him when my car is finished..
cheers danny
Live long and prosper!!
How thick are the liners?
I was given a 200 block which has had liners fitted ready to be honed the only thing that puts me off using it is that its been machined for what i'd guess is coopers rings gasket.
In your opinion Mark would this block be any good?
cheers
Paul
cheers
Paul
fraser9764
22
15-11-2011 03:42 PM
