Sierra RS500 Mk1
Old 04-05-2012, 07:38 PM
davidsw
davidsw's Avatar
Default Sierra RS500 Mk1
Hi guys , I have an rs500 suffering from low milage . Don't get me wrong great car strong engine but the cold clutch judder bugs me . This is combined with a low bite however when warm all is well . Is this typical or can some one advise a decent replacemt ( Like AP ) I'm not after a racing clutch but more comfortable drive that can take the odd thrashing . I do realise I'm may need to reface the flywheel . Last but least who is recommended to do it , as i cannot pretend anymore i can't be arsed to break my back and get it wrong . Thanks in advance .
Old 04-05-2012, 08:00 PM
gibbo frst
gibbo frst's Avatar
hello.... seeing as you location says marlow your best bet would be MA Developments in marlow... people travell from all over the country to have mark work on their cars so your lucky to have them on your doorstep.. we trailored mine 200 miles to get their..
Old 04-05-2012, 08:02 PM
botters
competant bodger
botters's Avatar
if standard to stage 3 power i would just go with a standard clutch and flywheel skim they last well so long as not abused with 6k launches and burnouts! other than that you cant really go wrong with an alcon 6 paddle, far better than ap's and are not heavy at all
Old 04-05-2012, 09:07 PM
davidsw
davidsw's Avatar
Thanks for that good advice new clutch is on its way - i don't think theres much point in playing with the origonal
Old 05-05-2012, 09:38 PM
Rob Virgo
Rob Virgo's Avatar
Hyd clutch converstion makes for a nicer drive all round....
Old 05-05-2012, 09:46 PM
sharky584
Shark conversions
sharky584's Avatar
see you are from marlow not far from you is kwr at norths estate piddington west wycombe guy called stuart will skim and balance your flywheel at a good price.
hope this helps.
Old 12-05-2012, 06:32 PM
davidsw
davidsw's Avatar
Default work done
Hi guys , i have done the work went for the AP organic clutch ( six springs ) kit. Went very well as you can expect crank seal gone which resulted in a quick dash to burtons. Result was great not heavy smooth power delivery . I was going to add pics but i can't ?.
Old 12-05-2012, 11:06 PM
Toe Knee
Toe Knee's Avatar
Has the clutch cable ever been changed out of interest?! They become heavy over time cos of the heat from the turbo etc and eventually will end up snapping!!!
Old 13-05-2012, 07:52 PM
davidsw
davidsw's Avatar
No not than i can see and the thrust bearing was really weak just old and the rear crank was oil seal was leaking , i also noticed i need to find a turbo to sump hose , mine is rock hard and weeping .
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
nico12
31-12-2015 04:42 PM
chowfornow
19-09-2015 10:47 PM
yorkie92
06-09-2015 05:34 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Sierra RS500 Mk1
