PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Register Photos KBase Gold & Trader Accounts FAQ Search Today's Posts Mark Forums Read GarageVendors
Search
Welcome to PassionFord
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
submit to reddit
Old 26-04-2012, 10:05 PM   #1
neo
Trader Score: (2)
neo is an unknown quantity at this point
Default water pump outlet the small one, where does it go ??
As per title on a 2wd water pump ive got a 38mm outlet at about 8pm and a smaller 24mm hose connection where does that connect too ?? And if its the heater and im not using a heater can i blank it off or do i have to reroute it elsewhere
Rob
neo is offline   Reply With Quote
Old 26-04-2012, 10:12 PM   #2
The Youth.
Trader Score: (1)
The Youth. is an unknown quantity at this point
Send a message via MSN to The Youth.
rob i connected mine to the outlet at the back of the head next to the blue water temp sensor via the oil modine
so it comes out of the pump through the oil modine then back to the head
steve
__________________
Mondeo ST TDCI and XR4x4 cosworth YB race car
NSSCC 2012 17th overall and 3rd in class B
Matt lewis motorsport supporting my racing in 2012
http://www.mattlewismotorsport.co.uk/
Reyland Motorsport Rebuilding my engine in 2013
The Youth. is online now   Reply With Quote
Old 26-04-2012, 10:18 PM   #3
The Youth.
Trader Score: (1)
like this rob
the 2 pipes usually go to /from the heater and as we both don't have them you just bypass them, use a 2wd metal pipe turned backwards then cut the pipe from the oil modine and connect it to like in the pic job jobbed
[img]http://www.clevelandrsoc.co.uk/attac...1&d=1292182511[/img]
steve
__________________
Old 29-04-2012, 11:02 PM   #4
neo
Trader Score: (2)
Cheers Steve ive used the outlet on the bottom of my header tank to go to the rear head connection but have a small 9mm one left available on the header tank i was thinking if i could go straight from the water pump to header tank top outlet ??
Old 29-04-2012, 11:04 PM   #5
neo
Trader Score: (2)
i could do with a 2wd coolant flow diagram and pipe diagram anyone got one ??
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
