Volvo 850 coil in Sierra
Hi
Do you think i can temporary replace the igniton coil in Ford Sierra 1991 DOHC with one from a Volvo 850. Need troubleshooting
850 only came with 5 cylinders. The middle number of the old Volvo'swould indicate the amount of cylinders. I.e. 740 and 760 were the same cars but with different engines.
Should that matter it's only a coil!
QUOTE=Bailes1992;5894169]850 only came with 5 cylinders. The middle number of the old Volvo'swould indicate the amount of cylinders. I.e. 740 and 760 were the same cars but with different engines.[/QUOTE]
You should be able to test with any coil of correct voltage to prove if there is any issues with the old one, but some will give a higher voltage than others
It should work, the output can vary, so long as it is only a temporary measure you should be ok I should think?
The only difference with coils is some cars have 'ballest ignition systems', this is where the loom has a resistor built in which reduces the power to 9V which the coil uses opposed to 12V, so you have 'ballest' and 'non ballest' coil's respectively.
Martin
Martin
nico12
31-12-2015 04:42 PM
Adam Graham
06-09-2015 06:04 AM
