3dr abs ecu
3dr abs ecu
Wanting a abs ecu for my 3dr the plug is yellow do i need a yellow top ecu or will any colour do, abs ecu was missing so im in the dark here on which ecu i need can anyone put my mind at rest cheers
To be honest I thought they were near enough unified, the Saph has a green connector, but I should think it may be the same ECU as a 3DR.
For example lesser model's and Granadas both use the same 'Tevas' system.
By any chance you aren't referring to the engine ECU with the yellow CO screw are you?
Martin
Martin
