New Sapph fuel lines? (also posted in Q&A section)
I have had some new fuel lines made up out of polymer coated Alli hardline the flow is in 10mm with -6 fiber braided s/s reinforced hose on each end, compression fittings both ends and crimped to the original fuel rail adapter, there is also a non return flap valve attached in-line at the engine bay end,
Then the return is done in 8mm due to the -6 hose being to big to clamp to the fuel regulator spigot and the nylon pipe at the tank end,
So the Questions are:
1, Does it matter if the return pipe is smaller
2, Do you really need a non return valve in the feed
3, What is the max fuel pressure of a stage 3 with a 044 pump
Also would like to know what you guys used, and any pic's of the connections you used would be nice
JK12
33
26-04-2021 12:09 PM
Dr. Ickxs
15-09-2015 10:15 PM
