Engine repairs
Engine repairs
I'm going to remove the engine from my car Monday to inspect the bottom end as I think it's spun a shell. If it has what will I need to buy to repair it?
What car is it?! If you can do a compression test as if the compression has dropped then it'll be worth doing the rings as well as the shells. Also worth looking at the pump as to work out why it may have spun a shell ie loss of oil pressure etc.
If you just do the shells then it'll be new shells, thrust bearings, if crank is damaged then a grind or at best a polish. New con rod bolts, sump gasket set.
Then whatever else yiu decide to do ie rings, would mean honing the bores then if the heads off if anything needs doing etc
It's 2wd saff cos. the engine has only done 10k since rebuild inc new pistons,shells etc
Speaking to mike rainbird this morning and he thinks it's definitely a shell by the sound of it :-( not very happy and will be phoning the engine builder in the morning to see what he has to say
Well I removed the engine and took the sump off and couldn't see anything wrong with it I took the engine to builders Saturday and had confirmation this morning that I'd cracked 2 pistons luckily nothing else is damaged. He's checked all the head and everything is fine. He said I'm very lucky as he has seen rods hanging out of blocks because of cracked pistons
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
