irish cosworth setup mapping etc.
Old 02-04-2012, 10:07 PM
paddy heffernan
heffo
paddy heffernan's Avatar
Default irish cosworth setup mapping etc.
im from kilkenny in ireland .can anyone tell me who would be able to do diagnostics , mapping fuelling setup etc in south of ireland .going to a ford garage here ya might aswell bring it to your mother ,they dont seem to be equipped for anything unusual at all .
Old 02-04-2012, 10:13 PM
DAN400
DAN400's Avatar
if its on standard management , no one over here can map it mate,
one of the reasons i went autronic on my car
Old 02-04-2012, 10:32 PM
andy130
andy130's Avatar
dan can anyone setup fuel etc on a cossie in the north?
Old 03-04-2012, 12:45 AM
NoRubNoDub
McGarrity Motorsport
NoRubNoDub's Avatar
Theres a few places i'll ask around tomorrow.
Old 03-04-2012, 08:08 AM
Tony Ryan
Tony Ryan's Avatar
http://www.westwardeng.com/
Old 03-04-2012, 07:20 PM
DAN400
DAN400's Avatar
if your just wantin the fueling checked i sure any of the tuners could check that up here
Old 04-04-2012, 09:39 PM
Rob Virgo
Rob Virgo's Avatar
What you needing exactly paddy
Old 04-04-2012, 09:55 PM
paddy heffernan
heffo
Default cossie
ive a problem with car that when it gets warm say in traffic or if you leave idling for a while car starts to splutter and run bad and eventually cuts out.if left to cool for 10 mins its fine again or if you get clear road its fine .i suspect its overfueling but am not sure.ive changed all sensors and no change ,where would i start to look for problem
Old 05-04-2012, 06:55 PM
D-Sport
D-Sport's Avatar
is your fuel pump noisy?, fuel filter changed ??
Old 05-04-2012, 06:59 PM
D-Sport
D-Sport's Avatar
get your co level checked at idle at ford and richen if low
Old 06-04-2012, 09:24 PM
paddy heffernan
heffo
Default cossie
fuel pump has a fair hum out of it alrite.would that not affect performance all the time rather than when its warm only or ticking over.
Old 06-04-2012, 09:34 PM
steven mc kay
steven mc kay's Avatar
i had a escort cossie one time and it did the same, it was a wireing problem to the fuel pump , it was over loading or something, when it was re wired it was fine.
thanks steven
Old 07-04-2012, 07:17 AM
D-Sport
D-Sport's Avatar
time to fuck that pump out my friend, or at the very least vheck all the wiring as stephen has suggested, last thing u want is a duff pump at 7000 rpm melting a piston or two
Old 07-04-2012, 09:24 AM
bigpaul
bigpaul's Avatar
Owen killen in downpatrick set my sapphire up , was like totally different car after he had it , 02844830238 , hes about 45miles from newry , would highly recommend him
Old 07-04-2012, 09:47 AM
PIO
PIO's Avatar
westcoastperformance.ie in Castleisland Kerry have a good rolling road and sound people. Set up my fuel and boost...
Old 07-04-2012, 12:42 PM
Paul_RS
Paul_RS's Avatar
A local rally man should be able to sort out that kind of fault and check your fuelling. Mapping of the weber marelli management can only be done in Great Britain
Old 08-04-2012, 11:34 PM
Rob Virgo
Rob Virgo's Avatar
Had a similar problem a few times with cossies and escorts, worth checking another coil,gpa one if you can borrow one.oil in old can type ones overheats and fucks up spark/voltage.
As said worth checking pump for voltage at pump and flow rate,disconnect return pipe at regular and run into container ( just be very carefully obviously )
I have a spare pump and coil if you wanted to go fir a spin....
Old 09-04-2012, 12:18 AM
andy130
andy130's Avatar
dan is it true that AI autosport have closed up?
Old 10-04-2012, 08:26 PM
paddy heffernan
heffo
Default hi
thanks guys for replys im waiting on fuel filter at moment old one looks ancient.might aswell eliminate that first and i will check power at pump tonite.
Old 22-04-2012, 02:57 PM
Markyrs
Markyrs's Avatar
Jonny (owner of ai) has set up at home now his number is 07900575128
manuel boeckx
13
03-10-2015 02:29 PM
Anutternutter
24
31-08-2015 01:24 PM
Red_bull
25-08-2015 06:27 PM
14-08-2015 07:29 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: irish cosworth setup mapping etc.
