ABS Wiring damage
ABS Wiring damage
Noticed recently the ABS sensor wiring on the passengers side front has been damaged by rubbing on the power steering pulley. Unfortunately it is the fixed loom part of the cable not the bit on the sensor. Has anyone done any repairs on these wires. It looks to be coax of some type. Wondering if you can remove the plug, cut back the wire and reattach. Thanks David.
