FAO Stu or James - Failed MOT - Emissions
Old 29-03-2012, 04:18 PM
Rex Kramer
Danger Seeker
Rex Kramer's Avatar
Default FAO Stu or James - Failed MOT - Emissions
Just had my Saph in for test and it failed on emissions, CO 7.2%, lambda 0.794 on fast idle. Normal idle CO is 5.5%.
Car has closed loop so shouldn't that keep the emissions in check. Hopefully Stu or James will see this
Anyone else had similar problems?
Rob
Old 29-03-2012, 04:43 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Mine was great when i had it fitted, CO at idle was perfect
You have a problem for sure
Steve
Old 29-03-2012, 04:51 PM
JamesH
JamesH's Avatar
That's very high indeed. I'm sure there will be a reason for it
Old 29-03-2012, 04:56 PM
fraser9764
fraser9764's Avatar
Coolant temp sensor?
phil_rs
yam yammer
phil_rs's Avatar
Lambda sensor fooked?
Old 29-03-2012, 04:58 PM
Rex Kramer
Danger Seeker
Rex Kramer's Avatar
Steve
Yep, I know I have a problem
Just need to work out what the problem is, lol.
Wasted spark and closed loop was only fitted last summer and has hardly done any miles since.
Rob
Old 29-03-2012, 05:06 PM
Rex Kramer
Danger Seeker
Rex Kramer's Avatar
Think I have a new spare CTS so will swap that and see if it helps.
Old 29-03-2012, 05:33 PM
botters
competant bodger
botters's Avatar
when mine was that high it was the map sensor at fault mate
Old 29-03-2012, 05:37 PM
JamesH
JamesH's Avatar
If you unplug the lambda sensor, then what happens with emissions/lambda?
Old 29-03-2012, 05:46 PM
Mark RS
Mark RS's Avatar
did you try to phone them?
Old 29-03-2012, 05:56 PM
GVK.
GVK.'s Avatar
Fuel pressure reg leaking?
Old 29-03-2012, 05:59 PM
Rex Kramer
Danger Seeker
Rex Kramer's Avatar
Yeah, was just after 5 so probably shut, will ring them tomorrow.
James, car is back at home no so can't check the CO.
Old 30-03-2012, 05:47 PM
JamesH
JamesH's Avatar
Do you have a wideband AFR gauge in the car?
Old 30-03-2012, 08:25 PM
Rex Kramer
Danger Seeker
Rex Kramer's Avatar
No mate, it is on the shopping list though
Got hold of a CO analyser so going see if I can narrow it down. Have a few spare sensors to try if needs be.
Spoke to James at MSD who gave me a few suggestions and offered to check it out if I could get it there.
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: FAO Stu or James - Failed MOT - Emissions
