Which engine oil in a cossie?
hi , im looking to change the oil in my cosworth this week but ive not owned it too long so im unsure which oil is best to use, the engine has been rebuild about two - three years ago so i guess its best described as slightly worn lol, just want to do my own service for piece of mind really , just seems to be alot of different oils used by people . thank you
Thought there would be a lot of different responses, think I'll use Mobil 1 15/50 as I think that's what is been using , I guess any thinner and the engine will start depositing it over my drive lol , thanks Everyone for the input.
Fuchs 10W/50 for me. I woulden't use anything less than a fully syn 50 weight.
Nothing wrong with Mobil either as it's liked by others.
Don't use 5W/30, it's too thin for these or any old engines, it's not so much that it will leak but it won't protect the engine properly, and it may burn it, remember these engines don't have the close tolerances of modern engines!
Martin
Martin
when people say an oil works well,,how can you tell between them.say you put in a 5 grade oil ,tried it,then drained,then tried a 15 grade oil.Now i ask ,what were the differences ?
It's just known that it works well, 5W is just sense really that it's to thin for this sort of application, and my theory is that a 50 weight will give good protection when hot, i.e. it won't break down and fully synthetic for top quality.
I guess some people who have tried the wrong vicosity etc may had a bad experience, hence why when they use something decent and it runs well thats there idea of "working well" lol.
Martin
Martin
Ive just changed from Castrol GTX to the new Mobil 1 1ow60 and its Shit imo. It was like pouring syrup into the engine. I knew pouring it in what was going to happen, i was thinking 'that cant flow very fast when its cold,' and sure enough, rattled its tits off. not very happy. The oil pressure readings are a little bit better than with the GTX but only 2-3 psi higher at cold or hot. That was a waste of Ł40 quid. Might try some Millers 10w50 before going back to the good old Castrol GTX.
So many urban legends about the oil. 5W isn't too thin, it is only the cold visco. A 15W-50 is too thick for cold days and bit thinner at temperature. A 5W-50 is very well and strong for cold and hot driving.
Even a Mobil 1 0W-40 is stronger than most people think (forget the myth about the engine is too old, way older engines tolerate 0W-40). First filling by Porsche, BMW and so on. Only the hot visco after the W can be too thin (for example a 0W-20 or 30 were too thin) but never a cold visco. People have to mind this fact.
the biggest difference about the cold and hot visco is the best (exceptions some ester oils):
0W-40 (not 5W- 10W- 15W-40)
5W-50 (not 10W- 20W-50)
10W-60 (not 20W-60)
Sometimes less is more.
Had never much oil consumption in the cossie with 0W-40. But now I've 5W-50 for the daily driver.
I used the 15w40, it was Ł10 in Asda on special offer. Engine was smooth and quiet. I would say that after 30 minutes of hard driving, the oil pressure was slighlty lower lower (2-3 psi, so not much) than usual operating temps, which showed it was thinning out a bit under heat. This is why I went with some recommendations and got the Mobil 1. Wished i never bothered. Going to try some Pro s 10w50 and if that doesnt improve things, I'll be switch back to the GTX.
cossie fan (unluckerly)
The difference between a 5w and a 15w is how thin they are when cold so a 15 will be thiner than a 5 which will be to thin! 10 is about right! the other number be it 40/50 or 60 is how thick the oil is when warm 40 could be said to be to thin and could cause weeping oil leaks i use a 40 in mine a 10w40 as its free thats what we have on tap at work i have good oil pressure cold and hot and no real oil leaks! You could also say a 60 is a bit to thick most tend to use a 10w50! You have to remember all the small oil ways and fine tolerances in an engine so oil thats to thick will not ciculate as it should plus oil thats to thin will give a lower oil pressure and not protect the engine as well as it should causeing things to wear faster
For the castrol people it was mentioned a while back by opies oil it wasn't too great once at running temps as other oils were hence more people use other brands. I used mobi 1 15/50 till they changed it to 10/60. Did an oil change the other day and have to agree with chrisa it did seem to rattle a bit to start but did clear up and hasn't seemed to since. Plus the fact it's available from every halfords is why I prefer using it!!
Well, I switch to Silkolene Pro S 10w50 and it seems to have quietened things down. I still have a residual tappet 'rattle' at idle even when hot, though the oil pressures etc are all good. Im guessing that the lifters on mine were on their way out and switching to the Mobil 1 has caused 1 or 2 to fail. going to stick some new lifters in while the oils new. more money
Mine only tends to rattle when I start from cold and they can take a few minutes to settle down, but once it's warmed up the engine is very quiet!
Look for 'INA' if buying new, you can if you are really determined dismantle the old lifters and clean them, also Wynns do a "hydraulic lifter lube", that may be worth a try before hand.
Martin
This bloody thread lol.............
I used to wait when Halfords had a sale on and get 3 for 2 etc. I used to buy the silver 5w40 fully sinthetic and had no issues even track days.
Now, I read this thread and think ooops, may be its a little too thin (not too worried about the cold side as only a summer / track car) and with the extra miles that add up then a decent oil might be a good idea.
Went into Halfords and went passed all the usual stuff but all I could find was 0w30, 5w30 etc. Not happy with that I decided to go to my local motorists shop. They had one can of Mobil 1 15w50 - I took it Ł50 bastard quid tho
I too was tempted to use Castrol GTX at Ł17 when I was in Halfords but decided against it due to it only being semi synthetic and the hard labour mine gets on track days.
Maybe piece of mind does cost a little more and when running a YB we should not scrimp on such vital things as oil. With everything else being so expensive though it would be nice to find the holy grail in oil if its out there.
Even the bloke with the posh voice thinks its the best
http://www.youtube.com/watch?v=m5PLJVgWTZw
Think its a 3dr in this one as well
http://www.youtube.com/watch?v=NI3PlFwSFQ0
I will be using this for the rest of her life!!!!
