3 door engine warning light
The above came on tonight on my way home from work, i did give it a bootfull and it came on around 4k and i felt it misfire. is this crank sensor ? the car is fitted with a group A coil ,new plugs and leads also fitted
You can read the code on a 3 door by counting the flashes and checking the code in the manual. This should then point you in the right direction for further checks to enable you to sort it. Not difficult to do at all you just short out 2 pins in a plug by the ecu.
I dont know how to read codes etc plus i dont have a manual mate . started doing it today again on the way to work ,julting alot once the red light came on
