Cosworth throttle position sensor ?
What would be the symptoms of a loose connection of the throttle position sensor be.Reason,,sometimes on idle i can hear the amal valve clicking on tickover,never really took any notice,when you slightly blipped the throttle it stopped.Anyway having a poke around(as you do),i tapped the tps and the clicking stopped,gave it a few more taps and the amal valve clicked with my tap.?? Any thoughts
thanks for the reply,i checked again after you said about it,it does seem to be a loose connection in the plug,as it does the same when you wiggle the plug about,its a 2wd tps(red) on an l8 ecu with msd c/l chip.
Zoggon
10-08-2015 10:39 AM
