windows not working
windows not working
hi all i have a sapphire on a 1992 k plate
its the glsi
has front electric windows but they dont work
i have:
put new battery on car
checked alternator for charging
checked power to window switches and thats fine
when the drivers window switch is pressed i can hear a single click noise from in the door but the window does not budge it the same on the passenger side
any ideas????
its the glsi
i have:
any ideas????
In answe to your previous post - yes you can put window switches with 4 switches in. I have disassembled and cleaned the contacts on my window switches heaps of times on my old XR4i. I think the windows get tired or sticky and draw more current and the contacts on the switches burn (arc) until they don't make contact any more. I pull the switch apart and clean the contacts with a fibreglass brush. Put it back together and it works for another 6 months or so. Keep meaning to wire in some relays but it would probably be better to fix whatever is causing the windows to draw too much current, David
It's either your windows aren't getting the correct power (due to bad switches as said) or the windows may be seized.
I would first verify the power that is leaving the switch, you could bridge the connections (Once you know the correct ones) and then if the windows work then the switches are at fault. They can be dismantled and cleaned, again as said.
Martin
Martin
Martin
Martin
cheers mate tried bridgeing but still nothing i have a motor on its way for passenger side so will see if that changes anything
thanks for everyones help
as for try pushing window down have tried that aswell
cheers.
If OP has bridged the switch and the result is still the same, then the switch is good.
It sounds as if the motor(s) are fine by the fact you can hear them when the switch is actuated, it may be the actual windows are siezed, in fact the motor is the last component I would suspect for failure!
It's worth removing the door card for a visual inspection, something you will have to do anyway for the new motor, while there lubricating the runners is a good idea.
They don't have a auto function feature.
Martin
Martin
Martin
Martin
thanks for the reply i shall try get an hour in today of having a look what the problem is cheers
Hi Martysmartie
You are correct Marty it is a faulty switch, I have now swapped the passenger side with a rear one ,that way the good lady can now operate her side, I have sprayed all switches now as aprecaution but will have a look on Ebay for another,
many thanks for the reply
Rammer
Rammer
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
