Bonnet gas struts
Same here, plus, on the wifes car its nicer having struts.... Just wanted to know if tailgate struts (or similar) would work? Nothing as elaborate as twins set up!
That's the one! I remember seeing some on a saff ages ago, fitted to one of the hinge bolts and the strut or wing... Sure they were tailgate struts? Just thinking it would be cheaper than buying a kit!?
Where did you get yours?
Bear with me matey, got in late tonight, but ill have a look tommow, if I get done early enough... Whatever its got on it, it makes it nicely weighted.... Looking at the Haynes manual, the struts look shorter than the pic above, but fitted with the usual ball joint bolts. I'll try an take them off the bm and have a bash at fitting them on the Saff, next day off.... Bear with me.
You looking at putting these on the S1?
OCD Victim
OCD Victim
Mk1 and Mk2 don't have them as standard, they are aftermarket kits to fit those models. You are after some from a car with a similar bonnet size and weight so that the struts will be the right lengths both open and closed, plus the rams need to be the right strength so they actually hold the bonnet open and not catapult it through the windscreen and not allow you to close it without bending it
OCD Victim
They actually used to do a kit for the MK5/6 Escort that had a special bracket for where it bolts to the shell due to the way the hinges are located. If you look around, you should be able to find some on places like ebay.
If not, I would probably go for something like a MK3 Golf kit (assuming your bonnet is not a pattern part as they are a lot lighter and will bend very easily), or something like this from a MK4/5 Fiesta
http://www.ebay.co.uk/itm/2509367309...9#ht_500wt_966
OCD Victim
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
07-10-2015 12:56 PM
