What remote iscv for Antilag?
What iscv can i use for antilag? Ive read somewhere that some of the vauxhall ones are good enough. Will i just need one of them too?
Thanks
Thanks
there two slots one on either side drill the center of these to 8mm and then drill two 6mm holes in between them so you have four holes instead of two slots
B1mbo
Ran, we don't drill an holes, do I consider it a bodge, no, it does a ok job. ALS is all about air flow (without going into ignition and fuel cuts etc) the more air the better the ALS. The top hat design with a bored out throttle body gives the surface area of a 17mm hole, which is alot of air so the alls an be very aggressive.
If you want it for a few pops and the noise I'm sure a hole through the original valve workings will be fine
if you need to run a second iscv i would get this housing
http://www.ebay.co.uk/itm/BILLET-ANT...5#ht_500wt_949
DixieTheKid
11
06-06-2020 11:20 AM
