Boost and idle promlem one for a cossie god
Right my car has decide it it wants to idle at 2000rpm and will only hold 1bar of boost instead of 2 bar anyone got any idea why ??
Cheers Martin
Cheers Martin
Like I said: without extra air you don't get 2000 rpm. Apparently most of the extra air comes from the ICV.
Is the just over 1000 rpm normal and the way it was setup? Or is that still a little bit too high?
Maybe a defective coolant temp sensor? Or wiring loose? And the ecu thinks it's -20 or -40? and limits the boost and raises the idle?
What ecu are you running? What eprom?
