GT30 water feed piping advice
I have replicated the alloy T series pipes in steel but now wondering if they are going to be fine internally if they are zinc coated or will they still corrode?
Unsure what to do now, the other option is to fit JIC fitting etc but would have preferred to go the metal pipe route
What have others done?
Has anyone used steel pipe or used the standard alloy pipes and welded on to alloy banjo fittings? in fact does anyone know of a company that sell M14 alloy banjo fittings that aren't JIC
I have nothing against JIC and teflon hose but i think the standard way is best if you can work it out
155lee
06-09-2016 11:10 AM
