uneven afr
uneven afr
I have stage 3 4wd and the afr is not consistant. I can set it at idle then drive it for a while and the afr reads much richer so I weaken it off and drive it again and it reads too weak.whats going on could it be the cold weather like -10C then changing to +2C being that there is more oxygen in colder air
If in doubt ! Flat out !
Hi ,
I had an L8 was always on the high side ( better for the turbo then to lean ) .
Was your basic rpm the same when checked ?
Colour from your spark plugs are also important there I think a lot of these aftermarket gauges are not good calibrated there my spark plugs were showing slightly brown what should be OK.
Afterwards I installed close loop from MSD and the needle was dancing all the time trying to adjust
Steven
Steven
wheelwizardrefurbs
22-09-2015 05:45 PM
Stu @ M Developments
Trader Parts for Sale.
127
02-10-2005 07:05 PM
