Feeding oil pressure pipe through bulkhead where?
07-01-2012, 04:19 PM
As title does anyone know off the top of their heads where the pipe can be fed through easy enough to fit the gauge in the centre heater vent location
many thanks
07-01-2012, 04:24 PM
chris isnt there a rubber grommet on the bulk head next to the one that the engine loom goes through?im sure theres one on mine thats not used.
07-01-2012, 08:20 PM
I'll have a look Jeff - not sure if the pipe is long enough but i will check and get back
Chris.
07-01-2012, 08:44 PM
i put mine through the engine loom grommet, there extra nipple's you can cut of and use to feed it through.
07-01-2012, 09:14 PM
Resident Wrestling Legend
there are some on the engine loom side and others on the drivers side
08-01-2012, 06:48 AM
Right lads cheers, it one of those jobs i should have done when the engine was out but never mind i'll look later - i know the grommet on the passenger side is cut as i had to use it for my Ryan loom so it will go through there if the pipe is long enough
08-01-2012, 03:24 PM
would it not be a better idea to fit a electric one instead of a capillary one if it ever leaks it will make a huge mess .
10-01-2012, 11:24 AM
im using an electric one for the same reason as what andy just said above
10-01-2012, 01:20 PM
I've never had one leak, I have the correct fittings - still haven't fitted the pipe through as its cold in the garage lol
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
dombanks
21-09-2015 08:38 PM
CrOwSoN15
14
03-09-2015 12:21 PM
