brake question
Old 27-11-2011, 04:15 PM
DixieTheKid
Pick-up P100 Power!
DixieTheKid's Avatar
Default brake question
Hi all, this may of been asked before but is it worth having std four pots up front and 4x4 vented discs and calipers at the rear? Thanks.
Old 27-11-2011, 05:27 PM
martysmartie
martysmartie's Avatar
Only in terms of heat disipation, as the solid discs will get very hot if driven enthusiastically, remember if you do this you will also need the calipers as well.
Martin
Old 27-11-2011, 06:30 PM
DixieTheKid
Pick-up P100 Power!
Many thanks
Old 28-11-2011, 02:16 PM
Char1ie
Char1ie's Avatar
On track my 2WD rear set-up caused the pads to disintegrate very very quickly. Changing to vented rear and 4WD calipers made the pads last much longer on track.
Prickly_buzz
07-12-2017 09:52 PM
155lee
27-10-2015 04:55 AM
Neil Clark
21
01-10-2015 07:02 PM
Sp3no
27-09-2015 07:23 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: brake question
