Zorst still Fookin Scrapping, Standard springs the answer?
Last Time, Get Off PF FFS
HI all. Sorry bit on an essay. End of my tether with this lol.
I have just fitted a magnex oe style exhaust to my saph 4x4. Now I am still scrapping everything if not a bit more considering the diameter of the exhaust pipes is smaller than my mongoose if have just taken off, and now I have taken a chunk out of the pavment tarmac going onto my drive which is on a hill and slant slightly down. I am planning on fitting standard ride height suspension. Will this cure it. Pic of them.
I have got the exhaust as high as I can for now but I think I can only get it up another 3 maybe 4cm's at a push. But I don thtink it will sort this problem.
My car is lowered only 25 mm so I dont eat the cv joints and on koni shocks all round.
I am going for Bayjoo standard ride height ones.
Does anyone else have this problem or am I the only one?
Who else has standard ride heightspirings?
cheeRS all.
cheeRS all.
I have the same system as you on my 3 door only with a smaller back box, i solved it by hanging the system using the thinner closer holes on the rubber mounts ,ie turning them on there side . very tight fit and does the job any more probs pm me
harris, i will try and put the zorst on the side bits of the mount tomorrow once i have put my new discs on, have a look and hope it works. it was a bugger getting it on the longer gapped holes lol.
m4tt274, hope they are 25mm but i am suspisious sometimes as i do have a steepish angle on the front driveshafts when she is on the deck. dont know what magnex say to hang it on as it is a hardly used second hand one.
ill update tomorrow night.
cheeRS.
cheeRS.
i said i would update but as you might have seen from other threads once i put my new discs on and went for a test run my shocks at the front rotted out and let go nearly writing of the front tyres lol. so it wont be till next weeks i can try and hang it higher. but now with new standard front shocks and springs the ride height at the front is higher at the mo.
till next week hopefully folks..
I also have the exact same problem with the same spec 4x4 as yours
Took the mongoose off as it was catching where the front pipe goes from offside to nearside.
Decided that magnex was a better fit,and that now catches just behind the twin boxes where the joint is flanged one side,and slip on joint the other.
Think the cutting disc and mig welder are going to pay a visit to it soon
Since my shocks collapsed last thursday I have put standard ride height springs and shocks at the front and it has raised the front (obviously). I am still planning hopefully this week to raise the exhaust so hopefully my problem is sorted.
STAFFY OWNER
13-09-2015 08:59 PM
Adam Graham
06-09-2015 06:04 AM
