Runs and stops????
Runs and stops????
Morning all
Its a 2wd turns over starts runs for approx 3 seconds then stops.
As soon as you touch the throttle it dies so it wont rev up either.
try to re-start it and it does.
Things i have checked so far;
Cap,rotor arm,leads,coil,ignition pad,injectors,spark plugs,TPS,lugs on crankshaft sensor and sensor gap and all the wiring back to the ecu to make sure there isn't a broken wire.
Any suggestions??
Thanks in advance
Any suggestions??
Thanks in advance
MAP sensor as said (Overfuelling) check the hose, and this first, the "flash code" system will also indicate a fault with the sensor.
If good, also do the "Wiggle" test on the CPS connector as they are known for having bad connections but would not have your symptoms.
Martin
Martin
Right thats the place to start then 2 people saying the same thing has to be a good sign
Thanks guys will report back later no at the car till 6pm
V6 Ka of Love
Does the fuel pump remain running after the car starts? Running for a few seconds always makes me think it's running on the fuel in the lines it had when the pump primed
Taken plug off map sensor car runs all be it rich as but changing the map sensor over for a new one makes it do exactly the same runs for 3 sec won't rev and stops
