SECS Monitor max boost reading
17-10-2011, 11:13 AM
I am right in thinking the max boost reading on a SECS monitor is 30.0 psi?
Cheers Rich
17-10-2011, 11:52 AM
it depends what Map sensor you are using.
17-10-2011, 12:05 PM
Mine peaks at 28.5 psi iirc
17-10-2011, 12:14 PM
In theory yes as it probably only has a conception of a 3 BAR MAP sensor and thus the maximum boost it could read would be 2 BAR or 30PSI.
Martin
17-10-2011, 12:28 PM
mine max's out at 28.4 psi
17-10-2011, 04:31 PM
Quote:
Originally Posted by
James @ M Developments.
3 Bar, but in the options you can only select 2.0 2.5 or 3.0, so if you had a 5 bar would it just go all screwie?
My Apexi boost gauge reads 2.3 bar but the peak recall on the SECS just says 30.0 psi so I presume it's maxed out.
Rich
17-10-2011, 04:48 PM
cossie fan (unluckerly)
im shore when i had one before going autronics mark told me they only go to 30psi when he fited one in mine
Last Time, Get Off PF FFS
I think it is 30psi. See what the alarm limit is and I think that would be it
17-10-2011, 05:37 PM
17-10-2011, 06:49 PM
Sonic Boom
Rich
yeah if you had a 5 bar it would read all wrong, but simon did tell me he could re calibrate them to work. Would be ideal to run one on its own 5 bar sensor.
doubt it will EVER happen though
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
