Sapphire Cosworth Factory Options
Does anyone have a copy of the options page from a sapphire cosworth brochure, preferably for the early 2wd models????
Or does anyone know if they had height adjustable columns as an option????
Cheers in advance!
Cheers in advance!
More boost Igor!
Sort of - foreign (ie, non UK) models had keep-fit rear windows, lacked the RS badge on the boot, and I think were also missing the Sapphire badge on the rear door quarter. To sort of make up for it, some countries had auto-levelling headlights and air con as standard (auto levelling headlights are a legal requirement in some countries).
motorsport nut job
I have an italian one, manual rear windows and no sapphaire badge on the rear quarters, had air con, but has an RS badge?
Not worried about the rear windows, don't sit in the back
Don't mention ze Vor
That's because the whole "Sapphire" thing only existed in the UK (and probably Ireland). In mainland Europe all models were simply called Sierra. Also, with the 1990 facelift, all models including hatchback and estate, got the "Sapphire" front with the shorter bonnet.
The RS badge was done away with on non UK models as Ford believed the Cosworth badge alone was enough to identify it, so it's strange yours has one?
Not sure about whats been said by shorter front though? This never changed apart from the Saphs had different bonnets and grills.
Martin
Martin
Martin
Martin
More boost Igor!
Martin
Martin
No mate, it wasn't the other way round. Until the 1989/90 facelift, all non-Cosworth Sierras (even the 4dr one that you call Sapphire) had long bonnets. From 1990 on, all models (except Cosworth) got the shorter bonnet .
Martin
Saphs in the UK always had the seperate grill (mind you, its design changed slightly with the 90 facelift), while Sierras always had the "long bonnet".
In mainland Europe there was never a difference between Sapphires and Sierras regarding the design of the front end. Until 1990 all had long bonnets, from 1990 on all had shorter bonnets (seperate grill as you call it).
This goes for all models except Cosworth and (I believe) P100.
3dr cossie
11
21-12-2015 03:38 PM
lukeeboy149
22-08-2015 04:29 PM
