replacing brake pads - Saff 2wd - how to ?
Hi guys,
Have taken the wheel off and taken "off" the caliper.
Tried to push the piston back, but it won't budge ?? ... handbrake is not engaged ...
Is there something im doing wrong here ?
BR
Thomas
BR
Thomas
DAmn ..... don't have a tool like that.
No other way to to it ? ...
Is is exactly this tool or is it model-based ? ...
http://www.ebay.co.uk/itm/Ford-Monde...item336ab10023
http://www.ebay.co.uk/itm/Ford-Mondeo-Fiesta-Ka-Focus-Brake-Caliper-Windback-Tool-/220833316899?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item336ab10023
http://www.ebay.co.uk/itm/PRO-RIGHT-HAND-BRAKE-CALIPER-PISTON-WIND-BACK-TOOL-/150610581912?pt=UK_Hand_Tools_Equipment&hash=item2 311171998
If you need one today Halfords sell them and are open till 5pm on a Sunday.
Rich
The pistons are threaded, so as said you need a "re-wind" (Not by Craig David ) tool!
By the way as a word of warning the "Laser" one which Halfords sell do not fit these, as the pistons are bigger!
Incidentally you can also use a pair of "Circlip pliers" if you have them to hand!
Martin
Martin
Resident Wrestling Legend
just remember that the pins need to be orientated to the 12/3/6/9 o'clock position in the caliper when you refit the brake pads as otherwise they won't fit
also make sure you slacken the handbrake cable as this will give you more movement in the caliper and will help in the next step
when you refit everything, start the car up and, when the brake pump finishing pumping and buzzing, press the brake pedal first to push the piston out and clamp it up BEFORE you adjust the handbrake
FlashRS
13
31-08-2015 06:02 PM
track.focus'd
12-08-2015 05:53 PM
