what clutch??
what clutch??
atm i have a 4 paddle clutch engines running about 400 ish mark, works fine etc but is heavy and juddery and quite annoying in traffic! been talking to a few that think a genuine ford motorcraft clutch or organic clutch will take 400 bhp? whats your opinions on this??
I would have thought a 4 - paddle is a bit much for 400bhp, a heavy duty organic clutch would probably be ok, i have a AP one in mine an thats about 320bhp, although if i was you at that power i would probably run a 6 - paddle...
How much bhp/nm will the standard clutch handle? I have T3 running 1.3 bar im not quite sure if my Cossie still has stock clutch or not. It doesn't slide and it works very well, and its perhaps little stiff. I should ask the previous owner about that.
Zee Germans are coming
cheers for all the replys guys.... ive already converted to hydraulic clutch ages ago, my pedal is quite light considdering what it was on the standad cable! the only issue i have is how juddery it is ie sitting in traffic etc, are the 6 paddles less juddery or will all paddles be the same?
Linkys
My old donkeys run fine last 6 years
http://www.ebay.co.uk/itm/ALCON-6-PA...ht_1007wt_1064
http://www.ebay.co.uk/itm/ALCON-6-PA...ht_1009wt_1064
Quality not to hard on the leg
