2wd rear beam help!!!
Hi i have a 2wd sierra and currently doin an under side resto on iv hear alot of diffrent storys about bushes and bearings for the rear beam can any 1 tell me wats best to go for or is it better to go with a 6 degree if so where is the best place to get 1 and wat sort of cost are they? The car will be used on the road with the odd track day here and there. Cheers
A lot of people recomend to put new ford bearings/bushes in the rear arms and either poly or solid mounts on the rear beam. But also highly recommended to change is the rear diff carrier to one of the uprated versions.
scs beam if your going 6deg,replacement standard bushes /ggr only once you see how the bush works you will understand,polly beam mounts and diff mount,and escos rear arb and 3dr front hubs and it will be spot on mate
cheeRS stu
cheeRS stu
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
