ecu bracket help please
iv brought a 4x4 saff that needed puting back together it was minus ecu and bracket iv brought a l6and iv got a ecu bracket but not sure weather its a 2wd or 4. (it has the abs ecu with it)
has anyone got a pic of one and where its positioned as it doesnt have the ecu cover like the 2wd...
thanks in advance!
thanks in advance!
The 4x4 does not have the ECU in the same place as pre face lift models, instead it sits in a bracket behind the passenger dashboard itself IIRC.
The L6 is not only technically, but physically different as well, i.e. the L8 (which your car would have had originally) does not have "Wings", L6 does. Incidentally you do know this won't be plug and play, i.e. the TPS is not only different but will require the wiring changing.
MSD were selling brackets but thats only if you have fitted L8 into a 2WD car, so tbh I think your going to have to make your own fitting up.
The 2WD certainly does have the ABS ECU mounted on top of the ECU, this is true of lesser mananged models as well, 4x4 is the same setup I should think!
Martin
Martin
07-10-2015 12:56 PM
DixieTheKid
14-09-2015 09:04 PM
