Idle control valve
Fast Ford snapper
Idle control valve
I've tried soaking it in WD40 with no luck, the car just acts the same if its plugged in or not.... stalling for the first 5 minutes of running.
Where's the best place to get a new one?
These were copies on Ebay, (i.e. not OE Weber) the feedback for the seller was good IIRC, the price was around £70.
That or if you can source a old Fiat, Lancia etc as certain models used the same management.
Have you tried applying power directly to the old one? Sometimes this can free them.
Martin
Martin
Fast Ford snapper
Cheers for that link.
Tried a factors today who phoned round all their suppliers and nothing could be sourced.
Now wondering if perhaps the wiring/ECU is at fault? As nothing at all is happening with it. Guess should check this before shelling out....
Fast Ford snapper
Any advice on how to test/check this problem would be appreciated....
Car cuts out when anything other than fully warmed up.
Unplugging the ISCV makes do difference whatsoever at any temp as it seems to be doing nothing.
More boost Igor!
It's powered by the fuel pump relay, and switched (earthed) by the ECU, so check for continuity between the negative pin on the multiplug and pin 16 on the ECU plug.
In either case it involves checking the values of the CTS and TPS, but on the latter they differ by the way of operation.
Check for +12V at the connector (It's permantely live WITH the engine running) or as I say putting power straight to it should open it fully.
Tbh there isn't alot that can go wrong with them!
Martin
Fast Ford snapper
Checked the ISCV connector and its got an earth with both the ignition on and off, but no power at all when on or off.
Wires look undamaged as far as I can see under the black plastic sleeve on that section of the loom.
Any ideas where to go next with this?
Fast Ford snapper
Doesn't have an amal valve, running an aftermarket boost controller.
How does the ISCV work anyway? I always thought it was a switch basically, but if its only connection is a power and earth I'm a bit lost on how it works (and what it does!)
It is earth controlled by the ECU, and should have an ign live, this maybe from the same feed as the fuel pump, so check it has power with the engine running,
just on ign you may find it has no power, because the fuel pump will prime and turn off.
Its functiion is simply to increase idle speed when commanded to do so, the base idle should be held on the Throttle body base idle screw, when hot the ISCV should be closed.
More boost Igor!
When the piston's in its closed position, the only air passing the butterfly is the amount determined by the butterfly's static adjustment, ie, enough to let the engine idle at 850rpm.
To control idle speed, all the ECU does is vary the length of the "open" pulses, ie, the amount of time it shorts the earth.
Fast Ford snapper
Right cool.... so when needed it'll kill the earth and then it'll pop out therefore adjusting/limiting the airflow?
I'll test for power again with the engine running when I'm back with the car...
As said above it's controlled by PWM, the ECU modulates the earth to open the valve by the desired amount. It has a live feed.
If you do check for power to ISCV do it with the engine running, otherwise as said you can get thrown down a false path thinking there is no power, as on ignition it will only have power for the duration of the pump prime. With the engine running it SHOULD have a permanent feed.
Martin
Martin
More boost Igor!
Yep - the default position for the valve is closed (it only has two positions: open and shut, hence the PWM), that's why when they're gummed up the car will be hard to start - there's loads of fuel going in, but not enough air. The ECU shorts the valve's earth to open it.
sorry to hi jack , i have a idle related problem which has appeared .
a few days back i had my airfilter box off to give k&n element a clean , since i put back together and it may just be a coincidence my car idles at about 1100 rpm not the 850 it was b4 and there is no difference whether valve plugged in or not , before i messed with filter when i unplugged iscv it would drop to base idle which was set at 850ish . The base idle screw will not adjust down any more but will increase idle if turned other way .
also used differnet super unleaded from esso not shell but don't think that would matter although i'm back using shell just incase .
any ideas , its a 4x4 btw and it smells like its overfuelling when just pottering round , runs and pulls fine apart from this .
anything i can check , it'll be weekend before i get near it again .
thanks in advance
Gaz .
thanks in advance
Gaz .
Fast Ford snapper
Right, tried with the engine running and it has power!
So I'm guessing it can only be two things.... ISCV stuck or an ECU fault?
I'm banking on the simpler of the two obviously......
This is kind of what happened to me when i was running standard ford plugs
I changed them to iridium plugs and it stopped completley.
Its worth a try m8.
if you need a set to try i have a few sets you can play with.
Regards, Stephen.
Also , Thanks for my Saph pics. they are awesome. Ill speak to you soon friend.
cheers
gaz
hopefully won't have any more problems before it comes of the road for winter jobs to be done .
thanks
gaz
