broke my diff!!!
Old 15-08-2011, 07:30 PM
cos358
cos358's Avatar
Default broke my diff!!!
i broke my diff in my 3dr earlier today and have a spare one was just wondering how much oil do i need for the diff? i want to completely drain the old oil out!
how long on average would it take to change with a jack and axle stands??
Old 15-08-2011, 08:17 PM
RS SHAUN
RS SHAUN's Avatar
I think I put 1ltr in mine mate!
Old 15-08-2011, 08:25 PM
cos358
cos358's Avatar
is that 1 litre full till comes out the plug?
Old 15-08-2011, 08:40 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Well it took me about 1hr 20 minutes to take mine out on my own on axle stands.
Be careful undoing the torx bolts on the driveshafts, clean all the crap out of the heads before you try and undo them.
Steve
Old 15-08-2011, 08:49 PM
RS SHAUN
RS SHAUN's Avatar
Think I found the capacity figure on here pal, I took the front cover off, because I wanted all the old stuff out!
Old 15-08-2011, 08:57 PM
cos358
cos358's Avatar
Steve
that whats worrying me the torq bolts, so all in all it should take me about 3-4 hours in and out and topped with oil fingers crossed, might be better to just borrow a ramp.
Old 15-08-2011, 09:12 PM
cos358
cos358's Avatar
did yours take exactly 1litre cause i done a search on here and 1 bloke said it takes 1.4litres with it all drained out but every1 else are saying 1litre so not sure if i should buy 1 or 2 litres.
Old 16-08-2011, 08:27 AM
Turbosimpsons
Turbosimpsons's Avatar
according to the ford manual it takes 1ltr SAE 90
Old 16-08-2011, 09:06 AM
COCHYN
COCHYN's Avatar
As above
Took me a good hour to swap it over, but as said make sure you clean out the torque heads on the shaft bolts as it will give you a real headache if you strip them. Which is very easy to do!
Old 16-08-2011, 09:19 AM
XRT_si
XRT_si's Avatar
If you have never done a diff before around an hour for fitting.
When you start doing them regularly around 40 minutes I found
Old 17-08-2011, 05:16 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Just put 1.4L in mine, that was to the top of the drain plug.
Steve
Iain Mac
30-09-2015 09:39 PM
mark r
29-09-2015 07:27 PM
DavidK
27-09-2015 02:55 PM
Fezman1
07-09-2015 09:34 PM
cbminis
07-09-2015 09:42 AM
Quick Reply: broke my diff!!!
