fuel line joints/ adapters
It's not really bhp dependant, it would be boost pressure dependant as the fuel pressure incresases with boost pressure. With a 1:1 rising rate fuel pressure regulator, and assuming the base fuel pressure is set to 3.5 bar at 0 bar boost, then 1 bar of boost would give fuel pressure of 4.5 bar, 2 bar of boost would be 5.5 bar etc.
When it comes to fuel lines I would over spec any joints by a big margin, you don't want high pressure fuel spraying anyware near hot engines / turbos / exhausts!
im trying to join metal fuel lines to braided to go into the filter and pump with one of these
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Hmm I would get -8 jic fittings silver soldered onto your hardlines rather than use those fittings. I've used them before, one snapped when assembling and one didn't.
JK12
33
26-04-2021 12:09 PM
Dubs44
19-09-2015 06:31 AM
