Outer cv boot
Last Time, Get Off PF FFS
Go to Kevin cooper and buy a cv boot cone, undo an move out the way the lower anti roll bar thing that connects to the hub and undo the 30mm nut that holds the shaft to the hub bearing etc etc and pull it out an go from there sliding the boot (well greased up inside out over the cone onto the shaft). If you speak nicely your local garage they might lend you the proper tool too, to fit the clips correcty. Hope that helps. Plenty of YouTube videos too.
Steve Escos
01-10-2015 06:57 AM
DavidK
27-09-2015 02:55 PM
