Wierd Clutch Problem
12-08-2011, 08:34 AM
Ok I have fitted a brand new ap clucth kit butI have no pedal at all and it wont go in gear if I do get it in gear it slipps its ass off
Enging is now out and its defo fitted correctly what I have noticed tho is when I tighten the cover the fingers all go flat
Any ideas guys before I burn the flipping thing
12-08-2011, 10:18 AM
sounds like the paddles are too thick. this is what happened to mine after having it reconned
12-08-2011, 10:19 AM
I am using a normal friction plate
Some 1 told to perhaps put washers behind the cover
12-08-2011, 10:20 AM
How did you get around it?
12-08-2011, 10:30 AM
Problem with the ratchet and pawl on the clutch pedal? Stretched clutch cable?
12-08-2011, 10:33 AM
no cable is good and ratchet the problem is defo clutch as the fingers are flat and the clutch arm is all the way forward before it hits the pressure plate
12-08-2011, 02:13 PM
Any 1 got any ideas as to what to do
12-08-2011, 08:25 PM
Quote:
Originally Posted by
cossie891
I bought a new clutch lol
13-08-2011, 09:04 AM
yatta
21-05-2016 10:31 PM
IainRS1700T
25-09-2015 06:44 AM
Rammer46
18-09-2015 08:31 AM
talon1
15-09-2015 10:27 AM
Flateric_2002
15-09-2015 08:41 AM
