Cosworth cam belt slipped
Ok my tensioner nut on my cosworth has some how came off while the car was driving but at a low speed and lowish revs was checked before hand by 3 people
Whats is the best and worst cases please peeps
I aint got the heart to lift the head off yet
We have towed the car back to my mates yard and dumped it there til I can be arsed too look again
All the valves will definatly be bent 100% hopefully it won't have damaged any guides though. Good luck. You should get a thread up step by step on what you've done and find
You're fucked 99,9% mate, had a cambelt problem few weeks ago and all exhaust valves are bend
Take a look here
https://passionford.com/forum/ford-s...07-2011-a.html
Take a look here
Bottom end should be fine - lift the head and inspect the pistons for damage - if non it's fine, source another head, skim and fit with a new head gasket job done
Edit to say - to buy a set of valve would cost loads - Burtons do new 4x4 valves for Ł436.13
This happened to me also, a fair few years back, bent all the valves, one in turn dinged the edge of a piston which then left slight scoring on one of the bores of the block, ended up just getting another engine.
Hope yours isn't this bad, good luck!
*** Sierra RS Custard ***
Not meaning to sound bitchy mate, but if 3 of you knew what you were doing how come it came loose after you all checked it was tightened? (and TBH why would 3 people check if one knew what they were doing, only takes 1 person to check surely?)
And more to the point, as im not mentioning it to try and have a go at you, but to help, what is going to be done differently next time to stop it happening again?
If it really was done up and checked by 3 people, you need to know WHY it came undone or surely there is nothing stopping it doing so next time?
Steve
Like I said mate its got just a normal 17mm nut holding it and a flat washer so I am guessing its wrong
I am going to replace the tensioner nut and stud for a new 1 this time
3 people checked it as I wanted to be sure on it all you know the rest of the build was fine its wierd how this has came loose
1 question tho which way should the tensioner be turned anticlockwise or clockwise?
I did clockwise is this wrong?
Chip should I loctite it next time?
3-door moonstone
Worth using the proper nut, even though they're a few quid each IIRC.
Also worth changing the bolts in the cam, I have had an old one of those work loose on me despite definately being torqued up correctly only a few miles before, luckily I spotted it before it came right off or that would have been equally nasty.
