ade 500 how did you get the hoses clip to stop on the body. did you bolt them into the bottom of the shell.
Yes the P clips on the brake pipe are nut and bolt through the floor and the clip.The double clips on the fuel lines are spacers really. I got little mini studs flanged nuts and little plastic spacers as the rear of the clip is concave. The back of the clips can then be fitted to the shell and the pipes fitted in and front of the clip bolted up from underneath.
Alex at torques.uk knows now exactly what u need to fit braided lines to a Cossie and think he's going to do kits.he done mine for me top quality too.best to give him a call, I used his clips to and used a rivnut to bolt them too the floor.
have u got a number or email address for alex at torques. have you got any pics of the fitting that you got from him.
many thanks brooksy
This is a dash 6 one.
orite pal, have you got any close up pics on how youve fitted them.
cheers
Alex is best contacted through ebay, just type in a search for cosworth -6 fuel filter fittings, il try and get a number for you. Iv got loads of photos but my pc is down at the moment and not sure if it's possible to post pics from a phone? Alex used my cradle as a base and has loads of pics he should be able to send you.
