help wasted spark kit
Hi i bought a wasted spark kit from msd sent in my l8 ecu for them to mod and they returned it 2 days later spot on
well my car was running fine on my l6 ecu but i had all the bits to switch to l8 so when i got my parts from msd i thought great some thing to do as i had the day off
i swapped my tps for a pf09 and fitted a an adapter to swap the wires round as i did not want to cut the loom,i followed the instructions given by msd for the wasted spark kit then tried to start the car but nothing just cranks so i went back though the instructions step by step and still nothing im starting to get a bit pissed so i have left it for to night and will have a go tomoz any one else had this problem
if i cant get it to fire ill ring msd monday just seems odd as i have followed the instructions but nothing
when i normally start the car i turn on the ignition and i hear the fuel pump buzz for a second then i turn the pump on and press the start button it fires up stright away
with the kit fitted i get a clicking from the injectors then nothing? please help before i set fire to it
its the piggy back board i had same problem with mine
its the piggy back board had same problem with my escort
hi bit of a update i put my set up back to how it was ie l6 ,removed the tps and adaptor re checked the instructions of the new loom which is fitted right i then borrowed my mates l6 with same spec as mine but with a wasted spark driver fitted plug this into mine switching on the car sounds like it use to a quick buzz from fuel pump then flick fuel pump on and crank .............................................nothi ng just turns over im not getting a spark ?
starting to wonder why i bothered with this kit im sure it must be something simple
update all sorted, sent the ecu back to msd they checked it over the chip was from a l1 ecu so they sorted it mailed it back, fitted it today and it started first time result big thanks to msd well pleased
but pretty fucked of with a member from here as he sold me the ecu "all good "as he put it i tried it on my car before i sent it he tells me .why sell it if it had problems if he had told me before it would have saved me a lot of hassle wanker
TT T38 Power
Name him
Glad your sorted
Steve
deathrider666
28-09-2015 06:12 PM
